[GRASS-user] FFTW framework problem
Richard Chirgwin
rchirgwin at ozemail.com.au
Tue Nov 3 15:48:29 EST 2009
Having had to rebuild a MacBook Pro, I've installed William K's 6.4.0RC5
build of Grass-GIS.
I'm running it under OS X 10.5.8.
Even though I have installed the FreeType framework (v2.3.11-1), ps.map
crashes reporting a problem with the framework:
> dyld: Library not loaded:
> /Library/Frameworks/FFTW3.framework/Versions/3/FFTW3
> Referenced from:
> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_gmath.dylib
> Reason: image not found
> Trace/BPT trap
The first time it happened, I did the following:
- Delete the Grass-GIS application
- Trash the installer receipt
- Reinstall the framework
- Reinstall Grass-GIS and the Grass-GDAL plugin
The problem still occurs. Any suggestions?
Richard Chirgwin
