[GRASS-user] FFTW framework problem
    Richard Chirgwin
    rchirgwin at ozemail.com.au
    Tue Nov  3 16:12:45 EST 2009
Many thanks! Fixed now.
Cheers,
Richard Chirgwin
William Kyngesburye wrote:
> The Leopard GRASS build still requires the FFTW framework, which is
> now in my download archives.  The next version, whenever that happens,
> will be like the Snow Leopard build with an internal FFTW.
> On Nov 3, 2009, at 2:48 PM, Richard Chirgwin wrote:
>> Hi,
>> Having had to rebuild a MacBook Pro, I've installed William K's
>> 6.4.0RC5 build of Grass-GIS.
>> I'm running it under OS X 10.5.8.
>> Even though I have installed the FreeType framework (v2.3.11-1),
>> ps.map crashes reporting a problem with the framework:
>>> dyld: Library not loaded:
>>> /Library/Frameworks/FFTW3.framework/Versions/3/FFTW3
>>>  Referenced from:
>>> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_gmath.dylib
>>>  Reason: image not found
>>> Trace/BPT trap
>> The first time it happened, I did the following:
>> - Delete the Grass-GIS application
>> - Trash the installer receipt
>> - Reinstall the framework
>> - Reinstall Grass-GIS and the Grass-GDAL plugin
>> The problem still occurs. Any suggestions?
>> Richard Chirgwin
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
