[GRASS-user] R and GRASS (readVECT6 problem)
Martin Mainzer martmai at gmx.de
Thu Nov 5 13:01:09 EST 2009
With R version 7.10.0 everything works fine with readVECT6() on my machine.
Thanks!
Martin
Roger Bivand schrieb am 29.10.2009 22:07:
> The last time this was seen, it was a locale problem. I heard today something
> from that questioner, who asked on the more relevant statsgrass list. Try
> setting your locale to an English one. I'll try to release the package with
> a patch, although the original questioner did not report success (but that
> could be because he was unable to install a source package).
> Roger
> Martin Maier-2 wrote:
>> Hi,
>> I am using the latest GRASS windows binary
>> (WinGRASS-6.4.0SVN-r39626-1-Setup.exe) on W2K. My R version is 2.9.2.
>> After starting R from within GRASS, loading the library(spgrass6) it is
>> not possible to use the readVECT6 command (with the South-Dakota
>> dataset) in R:
>>  > map <- readVECT6("bugsites")
>> Error in vInfo(vname) : Vector information not found
>> readRAST6() and gmeta6() both works fine.
>> Does anybody have the same error and can give a hint, why this error
>> occures?
