[GRASS-user] v.clean infinite loop? bug?
    Markus Metz
    markus.metz.giswork at googlemail.com
    Mon Nov  9 06:46:15 EST 2009
Markus Neteler wrote:
> On Mon, Nov 9, 2009 at 7:10 AM, Markus Metz
> <markus.metz.giswork at googlemail.com> wrote:
>> tomd123 wrote:
>> Threshold for tool=snap is maximum distance to another vertex in map units,
>> degrees for latlon. 3 degrees as threshold is too large, maybe this was the
>> reason for the long time? Threshold does not apply for tool=break, if given
>> it is ignored.
> [tool=break]
> Uhm, should the module say so? Or is that cluttering of messages?
It says so in the manual, and v.clean prints at the beginning a summary
of the tools and thresholds invoked. Not enough?
I find the currently printed summary including thresholds helpful, just
to make sure every tool is used with the threshold intended, and it's
quick and easy to figure out where a threshold value may be missing.
Markus M
