[GRASS-user] r.terraflow
Markus Neteler neteler at osgeo.org
Wed Nov 11 07:08:27 EST 2009
Hi Francesco,
On Wed, Nov 11, 2009 at 12:53 PM, Francesco Mirabella <mirabell at unipg.it> wrote:
> Hi Markus,
> I am new to code patching, yes there is space in the /tmp directory
> (about 14Gb) :
> I have now re-configured with both 64bit and large file support.
well, did you are recompile?
> I get the same error however I need e clarification:
> There exist two ami_sort_impl.h files, one in
> /../../../grass640_rc5/dist.i686-pc-linux-gnu/include/grass/iostream/
... that's not relevant.
> and the other in
> /../../../grass640_rc5/include/iostream/
... that's relevant.
> I have tried to apply the patch to the first, then to second and to both.
> However, I get very similar errors to the original error when using the
> patch for the first and for the second and for both.
Unless you don't recompile it won't work.
The "first" instance above is a copy created during compilation
of the "second" instance which is the real code.
1. Patch
2. configure
3. compile
4. install or run directly from GRASS from
   grass640_rc5/bin.i686-pc-linux-gnu/grass64
All clear like mud? :)
Markus
