[GRASS-user] r.in.arc Beyond the Man Page
M S
mseibel at gmail.com
Wed Nov 11 14:29:37 EST 2009
I've imported arc/info GRIDs before, but from .e00 files, or more
recently the exports from the arctoolbox as .txt files, which are
ascii files. I believe the files listed below are binary arc/info
GRID files.
Given the excerpt from the r.in.arc manpage, it seems to need an ascii file. (?)
"r.in.arc allows a user to create a (binary) GRASS raster map layer
from an ESRI ARC/INFO ascii GRID file with (optional) title."
Mark
On Wed, Nov 11, 2009 at 2:14 PM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
> I have files for 10M DEM in ARC/Info grid format that I want to use within
> GRASS-6.4.0RC5. I read the man page, but do not know which input file to
> use. I've not used this module before so I'm completely clueless.
> The souce data directory contains:
> dblbnd.adf info/ prj.adf vat.adf w001001x.adf
> hdr.adf log sta.adf w001001.adf
> The r.in.arc syntax includes the input string, but which of the above do I
> use? Or, do I need to convert each file separately?
> TIA,
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
