[GRASS-user] db.execute & transactions
Vincent Bain
bain at toraval.fr
Thu Nov 12 08:02:01 EST 2009
Hi List,
working on grass65 svn, with the "pg" dbms driver, I am trying to run
several slq statements from a shell script. These statements are
generated within a loop and I would like them to be executed in a
transaction.
I see it might not be possible this way :
echo "BEGIN TRANSACTION;" | db.execute
echo "myfirststatement;" | db.execute
echo "mysecondstatement" | db.execute
echo "COMMIT;" | db.execute
as it returns
WARNING: there is no transaction in progress
Should I dump all the commands in a temporary file $tmp then run
db.execute input=$tmp ? or is there a better way ?
Thank you,
Vincent.
