[GRASS-user] Stuck Getting Started
Rich Shepard
rshepard at appl-ecosys.com
Fri Nov 13 13:16:21 EST 2009
It's been about 6 years since I last used GRASS (4.3), but it makes no
sense that I cannot get started on a project now. I'm using the svn download
from several days ago.
1.) Created the database /usr4/grassdata
2.) Within /usr4/ started grass: grass64
3.) Tclgrass display comes up and asks again for the database; I enter
that.
4.) Click on 'Create new location using projection data'.
5.) The antiquated text entry window displays. I again enter the database,
the new location name (ORdem10), and the mapset (rbs).
6.) I'm shown the list of coordinate systems and select D; enter the name
'Oregon Conformal Conic' (which cannot be edited if I mistype a
letter), and answer 'y' because it's correct.
7.) Please enter a one line description for location <ORdem10>
ok? (y/n) [y]
ERROR: region for current mapset is not set
run "g.region"
ERROR: "/usr/local/grass-6.4.0RC5/etc/set_data" exited abnormally. Press
<enter> to continue.
Can't enter the datum, ellipsoid, and other parameters to define this
dataset.
Where do I start looking for the reason?
Rich
