[GRASS-user] Stuck Getting Started
Paul Kelly
paul-grass at stjohnspoint.co.uk
Fri Nov 13 17:35:00 EST 2009
On Fri, 13 Nov 2009, Rich Shepard wrote:
> On Fri, 13 Nov 2009, Paul Kelly wrote:
>> As far as I understand it that just means you are using the latest version
>> of the version tagged release_20090609_grass_6_4_0RC5 - for the latest 6.4
>> SVN you want the 6.4 branch rather than any specific tagged version:
>> https://svn.osgeo.org/grass/grass/branches/releasebranch_6_4 should be the
>> one I think.
> Paul,
> Hokay ... did the svn -co to a new directory and at the end I'm told that
> I've checked out revision 39721. That's the same revision as before. So I
> was using the latest code when I ran into that brick wall.
Sorry don't think I was clear enough - any branch, tag or version that you
update from SVN at this moment in time will show revision 39721, as that
is simply the latest change to have been made anywhere in the entire SVN
tree.
Paul
