[GRASS-user] compiled r.stream.* for Vista
Markus Metz markus.metz.giswork at googlemail.com
Sat Nov 14 06:56:28 EST 2009
Milton Cezar Ribeiro wrote:
> Dear all,
> I am needing to use r.stream.* under Vista (64bit),
> and as I am not able to compile it, I would
> like to know if I can find a compiled version
> of it, or how can compile the Addons.
> I tryed to start MSYS, get the r.stream.extract (for example),
> accessed the r.stream.extract directory and
> tryed type make, but I perceived that it is not so simple.
I think you need the source code in order to compile addons. See [1] for
compiling grass on windows using the OSGeo4W infrastructure.
Markus M
[1] https://trac.osgeo.org/grass/wiki/CompileOnWindows
