[GRASS-user] 6.5: Build Error
    Markus Metz
    markus.metz.giswork at googlemail.com
    Tue Nov 17 11:41:07 EST 2009
Rich Shepard wrote:
> On Tue, 17 Nov 2009, Martin Landa wrote:
>> no new info - wxPython headers are missing (only wxWidgets are
>> included) -
>> you need to install them...
> Martin,
> They're not in the source code.
Silly question: if you compiled wxPython from source yourself with make;
make install, did you also
cd $WXDIR/wxPython
python setup.py install
as described in $WXDIR/wxPython/docs/INSTALL.txt ?
Or check the SlackBuild script you used if it's doing that.
Markus M
