[GRASS-user] DXF to UTM32
Raffaele Morelli
raffaele.morelli at gmail.com
Wed Nov 18 05:03:23 EST 2009
2009/11/11 Micha Silver <micha at arava.co.il>
> Raffaele Morelli wrote:
> Hi you all,
> how can I transform a dxf (imported with v.in.dxf) layer in utm32
> coordinates system? I am currently doing some trials with v.transform with
> no success.
> Is the dxf in some coordinate system?
> If yes, then make a location based on that CRS, import the dxf into that
> location, then v.proj inot the UTM location.
> If not, then make an X-Y based location, import the dxf there, then again
> v.proj into your UTM location.
I have created an XY based location but whe using v.proj grass fails
complainig about PROJ file not found... so still stucked
Opening the dxf (converted using dxf2shp plugin) in Qgis reports that is a
"+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs"
regards
-raffaele
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091118/69a33b02/attachment.html
