[GRASS-user] accumulation map from directions map
    Markus Neteler
    neteler at osgeo.org
    Thu Nov 19 08:30:27 EST 2009
2009/11/19 Achim Kisseler <ak7 at jupiter.uni-freiburg.de>:
> Thanks, Jaroslaw for response,
>> there shoud be no problem if you have oryginal DEM
> I know, but I do NOT have the DEM. Thats the problem.
Ah, now I understand "is there a way in GRASS to build an
accumulation map from a directions map without a dem map?"
So: If you are on earth, you can get it here (mars/moon should be also
available somewhere :-):
http://grass.osgeo.org/wiki/Global_datasets
- SRTM
- ASTER GDEM
especially
http://grass.osgeo.org/wiki/ASTER_topography
If you need to start from the accumulation map and no way to
use a DEM, then I have no idea (but see the other comments)
Hope this helps,
Markus
