[GRASS-user] accumulation map from directions map
Silvia Franceschi silvia.franceschi at ing.unitn.it
Thu Nov 19 07:51:52 EST 2009
Hi Achim,
if you are trying to use an open source GIS for hydrological
applications consider to take a look at JGrass. There are a lot of
geomorphological modules.
Best regards
Silvia
> Hello again,
> I am still searching a method to generate a flow accumulation map from a
> flow direction map.
> I got the direction map from an arcgis user. In arcgis the module
> "FLOWACCUMULATION(FLOW_DIR)" would do this, but I want to use an open
> source solution.
> If anyone could give me a hint, where I could find a tool like this
> (inside GRASS it does not seem to be possible), I would be very grateful.
> Best regards,
> Achim
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
