[GRASS-user] Understanding Regions and Windows
Glynn Clements
glynn at gclements.plus.com
Sat Nov 21 17:12:30 EST 2009
Rich Shepard wrote:
> Starting grass64 from /usr4/grassbase/Oregon I request a listing of the
> region's boundaries and see this:
> GRASS 6.4.0svn (Oregon):/usr4/grassbase/Oregon > g.region -l
> north-west corner: long: 125:18:06.67543W lat: 41:38:42.416382N
> north-east corner: long: 125:18:06.327366W lat: 41:38:42.431669N
> south-east corner: long: 125:18:06.3167W lat: 41:38:42.29503N
> south-west corner: long: 125:18:06.664764W lat: 41:38:42.279743N
> center longitude: 125:18:06.496065W
> center latitude: 41:38:42.355706N
> rows: 1
> cols: 1
> I've no idea where these values are to be found because in
> /usr4/grassbase/Oregon/rbs/WIND I see this:
> [rshepard at salmo /usr4/grassbase/Oregon]$ less rbs/WIND
> proj: 99
> zone: 0
> north: 46.15916
> south: 41.933088
> east: -116.644278
> west: -124.719106
> cols: 1
> rows: 1
> e-w resol: 8.074828
> n-s resol: 4.226072
> top: 1
> bottom: 0
> cols3: 8
> rows3: 4
> depths: 1
> e-w resol3: 1.0093535
> n-s resol3: 1.056518
> t-b resol: 1
> Even this is incorrect from the definition of the region and projection
> using the wxPython UI, because the e-w resolution and the n-s resolution are
> both supposed to be in International Feet and were entered as 32.8286760.
The "proj: 99" indicates a cartographic coordinate system, but the
region boundaries seem more appropriate for lat/lon.
> I'd like to understand where the incorrect corners are found, why the
> region listing does not match the window in the rbs mapset (which matches
> the DEFAULT_WIND and WIND in the PERMANENT mapset, and how to fix this up.
What are the contents of PERMANENT/DEFAULT_WIND and PERMANENT/WIND?
