[GRASS-user] inverting DEMs
    Michael Barton
    michael.barton at asu.edu
    Sun Nov 22 00:26:11 EST 2009
Here are nviz versions of the 2 peaks maps for comparison:
http://www.public.asu.edu/~cmbarton/files/temp/peaks_from_terraflow_nviz.jpg
http://www.public.asu.edu/~cmbarton/files/temp/peaks_from_rparamscale_minic_nviz.jpg
It seems like the inverted DEM/hydrology method identifies major peak
*regions*, while the r.param.scale minic method finds individual
topographic highs. This makes sense given the way that both find peaks
differently.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Nov 21, 2009, at 9:48 PM, Michael Barton wrote:
> Compare
> with
>> http://www.public.asu.edu/~cmbarton/files/temp/peaks_from_rparamscale_minic.jpg
> (new version of the r.param.scale minic output)
> Michael
> C. Michael Barton
> Phone: 480-965-6262
> Fax: 480-965-7671
> On Nov 21, 2009, at 9:38 PM, Michael Barton wrote:
>> Hi Bulent,
>> I had a chance to mess around with the inverted DEM idea tonight.
>> Here's what seemed to produce the best results for identifying peaks.
>> r.mapcalc 'inverted.DEM = -DEM'
>> Then I ran r.terraflow on the inverted DEM to get a filled, inverted
>> DEM
>> r.terraflow elevation=inverted.DEM filled=terraflow.filled
>> direction=<required> swatershed=<required> accumulation=<required>
>> tci=<required>
>> (note that you will have to specify the other output maps too, even
>> if
>> you don't use them)
>> In the terraflow.filled map, I set the cells with value=0 to null
>> (places where the flow went off the edge of the map).
>> Then I subtracted the filled map from the inverted DEM to find the
>> sinks (=peaks of the original DEM)
>> r.mapcalc 'fill.difference =inverted.DEM-terraflow.filled'
>> If desired, these could then be inverted so that the larger the
>> number, the closer to the peak.
>> r.mapcalc 'peaks = -fill.difference'
>> The result is draped over a relief map.
>> Compare with the minic peaks map from r.param.scale
>> http://www.public.asu.edu/~cmbarton/files/temp/peaks.jpg
>> Michael
>> C. Michael Barton
>> Phone: 480-965-6262
>> Fax: 480-965-7671
>> On Nov 21, 2009, at 10:00 AM, grass-user-request at lists.osgeo.org
>> wrote:
>>> Date: Sat, 21 Nov 2009 07:01:37 -0700
>>> From: Bulent Arikan <bulent.arikan at gmail.com>
>>> Subject: [GRASS-user] inverting DEMs
>>> To: grass-user at lists.osgeo.org
>>> Message-ID:
>>> 	<f3d3690d0911210601j2679db9bh91e39960a4eb9206 at mail.gmail.com>
>>> Content-Type: text/plain; charset="iso-8859-1"
>>> Hi,
>>> I am trying to invert a DEM (i.e., make peaks basins and vice versa)
>>> but
>>> there does not seem to be a module for this. I am assuming this can
>>> be done
>>> through ' r.mapcalc ' which I have very limited experience.
>>> I also want to get ' r.prominence ' from the Add-ons site but the
>>> text file is not downloadable. Should I copy and paste to create a
>>> text
>>> file that contains the script?
>>> Thank you for all the suggestions,
