[GRASS-user] i.pca with wildcard input band
Markus Neteler
neteler at osgeo.org
Sun Nov 22 11:03:56 EST 2009
On Sun, Nov 22, 2009 at 4:36 PM, Peng Du <du at cs.utk.edu> wrote:
> Hi there
> Is there any way to specify multiple input bands to i.pca? I'm working with
> aviris data which has 224 bands and it'd be a disaster having to put each
> band like
Sure, no need to do that. See below:
> i.pca input=band1 at PERMANENT,band2 at PERMANENT, ..., band224 at PERMANENT
> I tried input=band*@PERMANENT and it doesn't work.
You can pass the output of g.mlist directy as input:
i.pca input=`g.mlist type=rast pattern=band* sep=","` out=...
The backticks in Unix shell execute the enclosed command first.
Or:
LIST=`g.mlist type=rast pattern=band* sep=","`
i.pca input=${LIST} out=...
Markus
