[GRASS-user] Old GRASS GIS compilation
Dylan Beaudette
debeaudette at ucdavis.edu
Mon Nov 23 17:48:49 EST 2009
On Monday 23 November 2009, Glynn Clements wrote:
> Firman Hadi wrote:
> > I am compiling GRASS 4.3 on Debian Woody.
> > My aim is to use r.le.dist function. I have tried to compile it but there
> > is one error that I can't solve. The error message is like below:
> > /home/firman/grass4.3src/src/libes/vask
> > make -f OBJ/make.rules
> > rm -f OBJ/V_call.o
> > gcc -I/home/firman/grass4.3src/src/include -DUSE_TERMIO -c V_call.c
> > V_call.c: In function 'V_call':
> > V_call.c:355: warning: comparison between pointer and integer
> > V_call.c: At top level:
> > V_call.c:430: error: static declaration of 'fmt' follows non-static
> > declaration
> > V_call.c:171: error: previous implicit declaration of 'fmt' was here
> > V_call.c:449: error: static declaration of 'centered' follows non-static
> > declaration
> > V_call.c:234: error: previous implicit declaration of 'centered' was here
> > make: *** [OBJ/V_call.o] Error 1
> > GISGEN failure at STEP: src/libes/vask
> > By this email, I would like to ask help from anyone who have experience
> > installing GRASS 4.3.
> You can fix these specific errors by moving the definitions of fmt()
> and centered() from the bottom of the file to the top.
> But you may encounter many more such errors trying to compile GRASS
> 4.3 with a modern C compiler. You could try using an older compiler,
> but that may not work with the headers from modern libraries.
Any reason not to use the current version of GRASS?
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
