[GRASS-user] g.region Options Yield Different Values
Rich Shepard rshepard at appl-ecosys.com
Tue Nov 24 08:36:34 EST 2009
On Tue, 24 Nov 2009, Glynn Clements wrote:
> Create the location anyhow and set the region from a map once you've
> imported one.
> If for some reason you need suitable bounds before you've imported any
> maps you can use use "m.proj -i ..." to convert lat-lon coordinates to
> projected coordinates (but projecting the corners of a lat-lon
> rectangle may be an underestimate; e.g. for LCC, the southernmost
> point will typically be somewhere in the middle of the southern edge,
> not one of the corners).
> For a more accurate estimate, create a lat-lon location, set the
> region, use v.in.region and v.split to create a sampled boundary,
> re-project that to the LCC location with v.proj, and use
> "g.region vect=..." to set the default region from the projected
> boundary.
Glynn,
   Thank you very much for the lesson. I'll make sure that the layers I need
for this current project are correct then start planning the model.
Much appreciated,
Rich
