[GRASS-user] installing addons without the source tree. But with
grass-dev!
Horacio Samaniego
horacio.samaniego at gmail.com
Thu Oct 1 11:26:25 EDT 2009
Hi, this is a question to more advanced users and perhaps developers...
I've been trying to install a module (r.stream.* from
http://heretic.livenet.pl/heretic) using the instructions provided in
the wiki to do so:
(http://grass.osgeo.org/wiki/Compile_and_Install#Addons)
However, I do not want to compile the whole grass src tree and are
trying to install this using the grass-dev provided by my distro (ubuntu
9.04) with no success.
The problem seem to be that the addon is unable to find tome libraries
that are actually in /usr/lib/grass64/include/grass
Here's the error:
io.c:1:27: error: grass/glocale.h: No such file or directory
In file included from io.c:2:
global.h:5:23: error: grass/gis.h: No such file or directory
The instruction say that I should place the addon in the
grass_src/raster directory which I don't have. However, I do have
the /usr/lib/grass64/include directory... how can I point the correct
path in the Makefile?
the content of the Makefile is:
MODULE_TOPDIR = ../..
PGM = r.stream.order
LIBES = $(GISLIB)
DEPENDENCIES = $(GISDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
default: cmd
Where should I point the MODULE_TOPDIR variable if I do not have the
grass_src tree?
any hint is appreciated and will be added to the wiki!
thanks!
H
