[GRASS-user] [Fwd: v.select error (latest grass_trunk)]
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Thu Oct 1 16:55:09 EDT 2009
Nikos Alexandris:
> > While the same v.select command (with op=overlap) works fine under
> > grass64, it does not under grass70. The error message is:
> > ERROR: Unable to open vector map <burned_areas__FINAL at nik> on level 2.
> > Try
> >        to rebuild vector topology by v.build.
> > Topology is there and is fine (checked under grass64 as well as under
> > grass70 with "v.info -t"). Is v.select broken?
Just to mention: I already have noticed the change from op=overlap >
op=overlaps.
