[GRASS-user] thresh in v.select?
achim
ak7 at jupiter.uni-freiburg.de
Tue Oct 6 05:22:18 EDT 2009
Hi all,
I report again a rounding problem, wondering why no one else seems to
have such problems.
Maybe someone con give me an good advice?
This time problem (see picture):
I have areas and lines and I want to remove the lines inside the areas-
I did:
-boundaries to lines ("arealines")
-patch lines and arealines
-break where they cross
-v.select -r -g operator=within
that should do, but due to ?roundings?, v.select does not do it
correct...(see picture) I would need a thresh in v.select, I guess,
hoping you might have an idea how to deal with it.
v.clean with snap does not work, because how can I tell the nodes at
line ends to snap to area boundaries.
Thank a lot in advance,
Achim
-------------- nächster Teil --------------
Ein Dateianhang mit Bin?rdaten wurde abgetrennt...
Dateiname : select_thresh.png
Dateityp : image/png
Dateigr??e : 23684 bytes
Beschreibung: nicht verf?gbar
URL : http://lists.osgeo.org/pipermail/grass-user/attachments/20091006/c8bc02e4/select_thresh-0001.png
