[GRASS-user] v.in.ascii in GRASS 6.4.0 RC5 - space delimited
	tables	are not imported - issue solved
    Milan Salek
    salek at chmi.cz
    Fri Oct  9 07:22:18 EDT 2009
FYI:
Thanks to Martin Landa, the problem is solved: The space (delimiter)
must be only one, more spaces between the items (columns) results in the
error, so it is necessary to reduce the number of spaces to one.
E.g:
echo -e "1 2\n3 4" | v.in.ascii out=x fs=space --o
does work
does not work (at least at my computer).
The problem is associated only with GRASS >= 6.4. At GRASS 6.3 I am not sure (do not have it available now), in GRASS <=6.2 there is no issue with multiple spaces (verified).
Best regards
Milan Salek
Milan Salek napsal(a):
> Dear all,
> in GRASS 6.4.0 RC5 (run on OpenSuse 11.0) I have encountered a problem
> in v.in.ascii when importing tables whose columns are delimited by
> space. The option 'fs=space' (with or without the apostrophes) does not
> seem to work. Only when the columns are delimited by non-space character
> (I'v tested '|' and ','), v.in.ascii works well. I store the atribution
> data in  dbf file.
> In previous versions of GRASS the problem does not exist.
> The workaround is quite easy (including some non-space delimiters to the
> imported table) but I would appreciate the next version to be without
> thit bug (or feature ...).
> Best regards
> Milan Salek
