[GRASS-user] negative categories?
    Achim Kisseler
    ak7 at jupiter.uni-freiburg.de
    Fri Oct  9 08:53:56 EDT 2009
from a raster map I get vector polygons with r.to.vect.
As I use the -v flag, I get one category-number for each value. This is
what I want.
My problem: v.to.db does not update negative cats! Is there any way to
handle this?
I dont want to loose the identification, nor miss the -v Flag: Having
raster-values in a column "value" is not clean, due to the fact, that I
have eg. to remove small trapped cells, calc center of gravity and more.
Thanks,
Achim
