[GRASS-user] buffer question
Achim Kisseler
ak7 at jupiter.uni-freiburg.de
Fri Oct 9 13:32:12 EDT 2009
It seems, that there are line-segments and a buffer is made for each. Do
you mean that?
Otherwise check:
http://grass.itc.it/grass64/manuals/html64_user/v.buffer.html
eg.
v.buffer input=map output=buffer type=line distance=100
Flags:
-s
Make outside corners straight
-c
Don't make caps at the ends of polylines
Cheers,
Achim
Giovanni Manghi schrieb:
> Hi all,
> a friend is asking me if there is a straight way in GRASS to make a
> buffer like the one represented in this arcgis screenshot
> http://evora.sigaberto.org/downloads/buffer.jpg
> the buffer would be calculated along a line splitted with v.split
> thanks in advance
> -- Giovanni --
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
