[GRASS-user] v.to.rast with text column
Achim Kisseler ak7 at jupiter.uni-freiburg.de
Wed Oct 14 06:34:34 EDT 2009
Hi Dylan,
v.to.rast has the option:
labelcolumn=name
    Name of column used as raster category labels
And the raster values have to be numeric:
column=name
    Name of column for attr parameter (data type must be numeric)
(http://grass.itc.it/grass64/manuals/html64_user/v.to.rast.html)
Try to make unique numbers from your string-column and convert them with
column=... and labelcolumn...
Achim
Dylan Beaudette schrieb:
> Hi,
> v.to.rast is letting me know that it does not accept text columns in an
> attribute table. Has anyone figured out a simple approach to making this
> work? I suppose that I could import the data into R, convert to factors, save
> the levels back to the table and use those... but there may be something out
> there that is simpler and can be done within GRASS. Also, would this be
> something worth adding to the v.to.rast code?
> Cheers,
> Dylan
