[GRASS-user] r.basins.fill usage
    MS
    mseibel at gmail.com
    Fri Oct 16 06:22:50 EDT 2009
Thanks to all for the help and guidence.
Mark
On Oct 16, 2009, at 6:20 AM, Jarosław Jasiewicz <jarekj at amu.edu.pl>
wrote:
> Hi
> try r.stream.basins from grass add-ons it has options (-c and -l
> flags) to generate subbasin without any manual work. Look also into
> tutorial on grass wiki about it (wiki -> dokuments ->r.stream.*
> Jarek
> Achim Kisseler pisze:
>>> Based on this excerpt from the manual, it seems the main
>>> external/perimeter watershed boundary, as well as the internal
>>> ridges
>>> need inputted?  "The raster map layer depicting ridges should
>>> include
>>> the ridge which defines the perimeter of the watershed. The coded
>>> stream network can be generated as part of the r.watershed program,
>>> but the map layer of ridges will need to be created by hand"
>>> My question is really about the need to manually digitize ridges
>>> inside the watershed boundary delineated by r.watershed.  As opposed
>>> to running r.watershed with a smaller threshold to get these smaller
>>> basin delineations within a given study area.
>>> If one has to manually digitize the internal ridges in a
>>> watershed, I
>>> wondered what the point of the module was.  It obviously has
>>> application, but it seems I am missing something obvious.
>>> Hope that is more clear.
>> Now its much clearer to me. Thanks.
>> In my opinion the description ao r.basins.fill is now very
>> detailed. I
>> don't really understand it. So maybe someone else can help and
>> maybe we
>> could find out and enhance the description:
>> I think this one:
>> "r.basins.fill generates a raster map layer depicting subbasins,
>> based
>> on input raster map layers for the coded stream network (where each
>> channel segment has been "coded" with a unique category value).."
>> is clear.
>> Input is: raster map X from "r.watershed stream=X"
>> Not clear to me is:
>> "...and for the ridges within a given watershed."
>> which is explained as:
>> "The raster map layer depicting ridges should include the ridge which
>> defines the perimeter of the watershed."
>> What should the parameter mean? How should that be stored in a
>> raster-map?
>> So try out:
>> -> take the stream-network and run r.mapcalc:
>> r.mapcalc "perimeter=if(X,5,null)"
>> Resulting map is a rastermap with value 5, where stream-network is
>> not
>> null. The five is raster-cells or map units or what else?
>> -> run r.basins.fill with that and see what happens.
>> I guess: from each network-segment the subbasin is created which
>> has a
>> minimum distance of 5 (cells?) to the stream. So its something like a
>> buffer.
>> ...in contrast to:
>> "...but the map layer of ridges will need to be created by hand (for
>> example, through digitizing done in v.digit)"
>> => the ridges-map here is a vector-file!
>> Achim
>> PS:
>> DESCRIPTION
>> based on
>> channel
>> segment has been "coded" with a unique category value) and for the
>> ridges within a given watershed. The raster map layer depicting
>> ridges
>> should include the ridge which defines the perimeter of the
>> watershed.
>> The coded stream network can be generated as part of the r.watershed
>> program, but the map layer of ridges will need to be created by hand
>> (for example, through digitizing done in v.digit).
>> The resulting output raster map layer will code the subbasins with
>> category values matching those of the channel segments passing
>> through
>> them. A user-supplied number of passes through the data is made in an
>> attempt to fill in these subbasins. If the resulting map layer from
>> this
>> program appears to have holes within a subbasin, the program should
>> be
>> rerun with a higher number of passes.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
