[GRASS-user] Missing some tools: v.db.addcol, for example
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Fri Oct 16 09:01:19 EDT 2009
> > On Thu, Oct 15, 2009 at 5:00 PM, Roger André <randre at gmail.com> wrote:
> > > My PATH while in GRASS already contains the scripts dir:
> > > GRASS 6.4.0RC4 (colombia):~ > echo $PATH
> > > /usr/local/grass-6.4.0RC4/bin:/usr/local/grass-6.4.0RC4/scripts:<snip>
> Mine too (the grass-6.4.0svn version).
> > > What I did find is that each script is under a directory by the same
> > > name in the scripts dir. So for example, d.redraw is in:
> > > /usr/local/grass-6.4.0RC4/scripts/d.redraw/d.redraw
> On Fri, 2009-10-16 at 11:44 +0200, Markus Neteler wrote:
> > Wow. This is not desired of course. I am a bit surprised.
On Fri, 2009-10-16 at 12:18 +0200, Nikos Alexandris wrote:
[Replying to myself]
> Maybe I don't get that right but I have grass64_release, grass640_0rc5,
> grass6_devel, grass_trunk. In all of them the scripts (sub-)directory
> contains a directory for each script. In each script-directory there are
> description (html) files and also README, Makefiles, etc.
> Isn't this ok?
Yes it is (for the source code :-). Under /usr/local/grass... (the
installed stuff; currently I use the 64 version) all scripts are bare
files under the scripts directory.
> > > I'm going through all of these now, and removing the dir and leaving
> > > the script. Somewhat tedious, but the scripts appear to work.
> > Would you mind to check if this is still valid for RC5?
Nikos
