[GRASS-user] Importing Vector Data
    Micha Silver
    micha at arava.co.il
    Fri Oct 16 16:34:07 EDT 2009
Bob Byer wrote:
> All,
> I work extensively in the state of Delaware and the mapping
> information that they provide is based on ESRI ID 102257 with an ESRI
> WKT Name of NAD_1983_HARN_StatePlane_Delaware_FIPS_0700.  As a new
> user of GRASS, what would be the best way to import that data?
> Ultimately, I wish to reproject state plane meters to state plane feet
> then use those files to import into a MODFLOW project.  Perform the
> modeling, then export that information back to GRASS for additional
> processing.
I see in the EPSG database that NAD_1983_HARN for Delaware with units of
feet is EPSG code 2880:
# NAD83(HARN) / Delaware (ftUS)
<2880> +proj=tmerc +lat_0=38 +lon_0=-75.41666666666667 +k=0.999995
+x_0=200000.0001016002 +y_0=0 +ellps=GRS80 +to_meter=0.3048006096012192
+no_defs
Does  that exactly match ESRI's 102257?
And the EPSG code for for the CRS with meter units is  2776, as listed
at the bottom of your website..
So if you create two locations, one based on each of the EPSG codes, you
can then import your data (into the correct location), and reproject to
the other location to get units in meters.
> In case there is interest, the web site
> http://datamil.delaware.gov/geonetwork/srv/en/datadownload
> Thanks in advance,
> Bob
> This mail was received via Mail-SeCure System.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
