[GRASS-user] HowTo fix country border topology problem?
Brent Wood
b.wood at niwa.co.nz
Sun Oct 18 17:26:00 EDT 2009
Roger,
If you load the data into PostGIS, this sort of operation is relatively
trivial....
One of the reasons I don't use GRASS is that projections are tied to
workspaces, instead of datasets & I use data in several projections
concurrently, I don't want to have to keep several copies of the same
dataset as required by GRASS.
If you are interested in looking at this approach, feel free to contact
me.
Brent Wood
Cheers,
Brent Wood
Brent Wood
DBA/GIS consultant
NIWA, Wellington
New Zealand
>>> Roger André<randre at gmail.com> 10/18/09 6:03 AM >>>
Hi Martin,
Thanks, that is a exactly the problem. Your page is perfect for
showing the cause and solution.
One question though, since the solution relies on removing polygons
whose areas are less than a minimum threshold, how can we do this
accurately with a global data set? I suppose I could extract each
country, reproject it to a local projection, clean out the bad
polygons, then reproject to lat/lon, and finally patch all of the
separate countries back into single file.
Roger
On Sat, Oct 17, 2009 at 12:57 AM, Martin Landa <landa.martin at gmail.com>
wrote:
> Hi,
> 2009/10/17 Roger André <randre at gmail.com>:
>> Tried the v.extract route - it didn't help. The little segments came
> sure, because there are no 'lines' - just 'boundaries' and 'centroids'
> which constract 'areas'.
>> along. So I decided to look at the original data and pull one the
>> polygons from it, to see if I could spot anything strange about it.
I
>> did find something, maybe, maybe one of the experts here can explain
>> it.
>> Here is what v.clean reports:
>> Number of nodes: 55
>> Number of primitives: 59
>> Number of points: 0
>> Number of lines: 0
>> Number of boundaries: 46
>> Number of centroids: 13
>> Number of areas: 13
>> Number of isles: 9
>> This country should have 9 areas, which matches the number of isles.
>> I'm trying to figure out how to remove the extra areas (rmarea thresh
>> value is tricky), but I wonder if there is a way to make the areas
>> match the isles?
> I was facing probably to the similar problem, it's described here [1].
> Sorry it's in Czech, anyway from the commands you can probably
> understand what was the problem. I hope it can help you a bit.
> Martin
> [1]
http://gama.fsv.cvut.cz/wiki/index.php/GRASS_GIS_-_Konzistence_vektorov%C3%BDch_dat
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
grass-user mailing list
grass-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-user
NIWA is the trading name of the National Institute of Water &
Atmospheric Research Ltd.
