[GRASS-user] having problems importing shapefiles
Erik Lash
lash.erik at gmail.com
Wed Oct 28 19:32:30 EDT 2009
I've tried to duplicate your problem on the most current release (r39626-1)
on WinXP SP3 but every shapefile I tried imported without error.
However, I've noticed that DBF files still do not import with db.in.ogr and
throw an error that the table can not be found like they did with the
previous version.
-Erik
> -----Original Message-----
> From: grass-user-bounces at lists.osgeo.org [mailto:grass-user-
> bounces at lists.osgeo.org] On Behalf Of Carlos Grohmann
> Sent: Wednesday, October 28, 2009 5:18 PM
> To: GRASS user list
> Subject: [GRASS-user] having problems importing shapefiles
> Hi all,
> I'm facing some serious issues importing shapefiles (latest svn). I
> always end up with a buffer overflow, no matter the size of the file
> (error msg at the end of this)
> I did managed to use v.external, but if I try to reproject the linked
> shp, it comes without any table..
> I also noticed that sometimes, using wxgui, I see python eating about
> 40% of my cpu... this looks bad
> Just some more notes on wxgui: v.overlay: window title set at
> "v.overla", and in v.external, the fiels for the dns path is set to be
> too long, it should be smaller.
> On a side note: I know that programming the new GUI is a lot of work,
> but every time I have to use r.mapcalculator on wxgui, I just give up
> the annoying clicking and usually just start the old tcltk GUI so I
> can run the stuff as I am sued to it, like "if (A > x, null(), B)".
> Can we have something like that in wx??? please?? :)
> tks
> Carlos
