[GRASS-user] Possible bug in v.edit
Marc-Antoine Nüssli marc-antoine.nuessli at euratlas.com
Tue Sep 1 08:10:26 EDT 2009
Dear Grass users,
I get a very strange result with v.edit. Here is the story:
I have imported a vector map from a postgres database and there are 3
overlapping areas. Then, I try to get the feature ids(not the category) of
the overlapping areas by using (as the overlapping areas appear in layer 2
with cat=2):
v.edit map=test_shapes_newi layer=2 tool=select cats=2 type=centroid
Ans the result is:
29,27
Selecting features...
2 of 29 features selected from vector map <test_shapes_newi at PERMANENT>
v.edit complete.
Thus, only two features are selected... instead of 3....strange
Then, I tried to print the category(in layer 1) for all features using:
v.category input=test_shapes_new option="print"
and the result is:
4
6
7
2
1/2
1
1/3
3
5
3/5
So, we clearly see that 3 features have two categories in layer 1(and thus
are overlapping), which is consistent with what is indicated by v.in.ogr
(and also with what I can see when I display the map)
Then, if I get the ids of features with cat=1 in layer1:
v.edit map=test_shapes_newi layer=1  tool=select cats=1 type=centroid
I correctly get 3 ids...
But if I ask for the features with cat=3 in layer1:
v.edit map=test_shapes_newi layer=1  tool=select cats=3 type=centroid
I get only 2 ids:
29,27
v.edit complete.
which is clearly wrong if we compare with the list of categories printed
above...
I really don't understand what is going wrong. The only reason I can think
of is a bug in v.edit....
Below, I have pasted the testfile I used to produce these results. Please
try to redo and tell me if you have the same problem. Moreover, if you look
at the text file, we can clearly see that there are three features with two
categories...
By the way, I take the opportunity to ask if someone knows an easy way to
transform overlapping areas into simple areas. Basically, I just want to
choose one of the two(or more) categories associated to an area and assign
it as the only category for that area. And I don't care about which category
is chosen among the 2 possible.
My data are the areas of countries and thus the overlaps I got are just
because of some problems in the none-topological version of the data. So, I
just need to assign randomly these overlaps to one of the neighbor area.
I tried v.clean tool=rmdupl but it does nothing at all...
Now, I am fighting with v.edit and I get the problem presented above...
So, if someone has an easy solution to this problem, I would very glad.
Thank you in advance!
Marc-Antoine Nüssli
----------START ASCII GRASS STANDARD FILE----------------------
ORGANIZATION:
DIGIT DATE:
DIGIT NAME:   nuessli
MAP NAME:
MAP DATE:     Tue Sep 01 13:01:32 2009
MAP SCALE:    1
OTHER INFO:
ZONE:         0
MAP THRESH:   0.000000
VERTI:
B  5
 158          131
 211          301
 108          333
 75           254
 158          131
B  5
 171.67467949 102.62660256
 182.29166667 94.41346154
 194.71153846 71.77724359
 191.30608974 72.17788462
B  4
 116.20338236 147.39430963
 114.22292076 131.55061682
 121.15453637 135.51154003
B  2
 62           77
 98.3258427   111.53932584
B  2
 123          135
B  2
 43           77
 62           77
B  3
 62           77
 69           77
B  6
 114          130
 115          150
 66           259
 35           265
 43           77
B  3
 158.08252615 122.19914762
 156          116
 168.5464684  106.24163569
B  3
 183          95
 195          72
B  3
 123          135
 71           255
B  2
B  7
 191          72
 151          70
 37           72
 37           160
 40           74
 62           77
B  3
 217          307
 162          136
 181.12359551 190.78651685
B  3
 199          242
 273.24466019 221.44466019
B  4
 441          175
 276          289
 217          307
B  4
 195          72
 414          45
 436          172
B  3
 199          244
B  2
C  1 1
 144.59283467 243.00698455
 1     4
C  1 1
 183.51855004 87.21392108
 1     6
C  1 1
 116.96146785 138.87668756
 1     7
C  1 1
 65.45911571  169.69098179
 1     2
C  1 3
 80.70905903  93.08952149
 1     1
 1     2
 2     2
C  1 1
 135.07702133 128.59957381
 1     1
C  1 3
 161.92770396 113.80227654
 1     1
 1     3
 2     2
C  1 1
 297.85655015 136.60482313
 1     3
C  1 1
 275.17021301 221.55107616
 1     5
C  1 3
 237.76816343 231.7223301
 1     3
 1     5
 2     2
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090901/0e336f69/attachment-0001.html
