[GRASS-user] subsampling to a coarser resolution
    jamesmcc
    jlmccreight at gmail.com
    Wed Sep  2 12:50:01 EDT 2009
Hi Markus-
I've  used r.resamp.stats alot, but in this case it dosent appear to be
flexible enough to just select the cells I want to do stats on. It's still a
lovely routine, however. It would be nice to be able to supply it a matrix
mask to make it more flexible, then it could do what I want. Then, it could
cook me lunch too. :)
I've now tested the bilinear method in r.resamp.interp, exactly as suggested
by Glynn and it works perfectly going to coarser resolution. I imported my
interpolates/aggregates made in IDL and r.stats shows only a zero category
for the difference of the rasters!
Still wondering about r.what and row,col inputs...
thanks!
Markus Neteler wrote:
> On Wed, Sep 2, 2009 at 4:42 PM, jamesmcc<jlmccreight at gmail.com> wrote:
>> Thanks Glynn,
>> I didnt realize that bilinear was what I was doing, though I'm familiar
>> with
>> it. This should work, though I immediately become concerned by the first
>> line of the documentation
>> r.resamp.interp - Resamples raster map layers to a finer grid using
>> interpolation.
>> since I'm not going to a finer resolution. I noticed that you are the
>> author, so I thought I should say something! :)
> see also:
> http://grass.osgeo.org/grass64/manuals/html64_user/r.resamp.stats.html
> r.resamp.stats - Resamples raster map layers to a coarser grid using
> aggregation
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://n2.nabble.com/subsampling-to-a-coarser-resolution-tp3563929p3567972.html
Sent from the Grass - Users mailing list archive at Nabble.com.
