[GRASS-user] error compiling GRASS "checking for pj_get_def in -lproj... no"
P Kishor punk.kish at gmail.com
Thu Sep 3 15:27:08 EDT 2009
On Thu, Sep 3, 2009 at 2:23 PM, Markus Neteler<neteler at osgeo.org> wrote:
> On Thu, Sep 3, 2009 at 2:58 PM, P Kishor<punk.kish at gmail.com> wrote:
>> I am trying to compile GRASS on Mac OS X. For now, configure is
>> failing to find libproj correctly. Here is what I get
>> punkish at Lucknow ~/Projects/grass-6.4.0RC5$ ./configure \
>> --with-proj-includes=/usr/local/include \
>> --with-proj-libs=/usr/local/lib \
>> --with-proj-share=/usr/local/share/proj \
>> checking for location of External PROJ.4 includes... /usr/local/include
>> checking for proj_api.h... yes
>> checking External PROJ.4 version... 461
>> checking for location of External PROJ.4 library... /usr/local/lib
>> configure: error: *** Unable to locate External PROJ.4 library.
> In config.log (at bottom) some details should be shown why the
> pj_get_def test fails.
Thanks Markus. This is what I have
punkish at Lucknow ~/Projects/grass-6.4.0RC5$tail -20 config.log
configure:7025: checking for location of External PROJ.4 library
configure:7050: checking for pj_get_def in -lproj
configure:7067: gcc -o conftest -arch x86_64 -Os    -L/usr/local/lib
-arch x86_64 -arch x86_64 conftest.c -lproj   1>&5
ld warning: in /usr/local/lib/libproj.dylib, file is not of required
architecture
Undefined symbols:
  "_pj_get_def", referenced from:
      _main in ccjErGbn.o
ld: symbol(s) not found
collect2: ld returned 1 exit status
configure: failed program was:
#line 7056 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error.  */
/* We use char because int might match the return type of a gcc2
    builtin and then its argument prototype would still apply.  */
char pj_get_def();
int main() {
pj_get_def()
; return 0; }
Puneet Kishor
