[GRASS-user] error compiling GRASS "checking for pj_get_def in
-lproj... no"
P Kishor
punk.kish at gmail.com
Thu Sep 3 16:15:31 EDT 2009
On Thu, Sep 3, 2009 at 3:09 PM, P Kishor<punk.kish at gmail.com> wrote:
> On Thu, Sep 3, 2009 at 3:04 PM, Markus Neteler<neteler at osgeo.org> wrote:
>> On Thu, Sep 3, 2009 at 9:27 PM, P Kishor<punk.kish at gmail.com> wrote:
>>> On Thu, Sep 3, 2009 at 2:23 PM, Markus Neteler<neteler at osgeo.org> wrote:
>>>> On Thu, Sep 3, 2009 at 2:58 PM, P Kishor<punk.kish at gmail.com> wrote:
>>>>> I am trying to compile GRASS on Mac OS X. For now, configure is
>>>>> failing to find libproj correctly. Here is what I get
>>>>> punkish at Lucknow ~/Projects/grass-6.4.0RC5$ ./configure \
>>>>> --with-proj-includes=/usr/local/include \
>>>>> --with-proj-libs=/usr/local/lib \
>>>>> --with-proj-share=/usr/local/share/proj \
>>>>> checking for location of External PROJ.4 includes... /usr/local/include
>>>>> checking for proj_api.h... yes
>>>>> checking External PROJ.4 version... 461
>>>>> checking for location of External PROJ.4 library... /usr/local/lib
>>>>> checking for pj_get_def in -lproj... no
>>>>> configure: error: *** Unable to locate External PROJ.4 library.
>>>> In config.log (at bottom) some details should be shown why the
>>>> pj_get_def test fails.
>>> Thanks Markus. This is what I have
>>> punkish at Lucknow ~/Projects/grass-6.4.0RC5$tail -20 config.log
>>> configure:7025: checking for location of External PROJ.4 library
>>> configure:7050: checking for pj_get_def in -lproj
>>> configure:7067: gcc -o conftest -arch x86_64 -Os -L/usr/local/lib
>>> -arch x86_64 -arch x86_64 conftest.c -lproj 1>&5
>>> ld warning: in /usr/local/lib/libproj.dylib, file is not of required
>>> architecture
>> This will be the problem: "file is not of required architecture"
> I compiled PROJ.4 with the standard instructions, nothing fancy at
> all. It has worked fine with MapServer, PostGIS, GDAL and GEOS
> installations so far. GRASS is the only one choking up with the "file
> is not of required architecture" message, so I am loath to tinker with
> what works with 4 other programs just so it can possibly work with one
> other program, and possibly break the other four.
> could it be because I first did the following
> export CFLAGS="-arch x86_64 -Os"
> export CXXFLAGS="-arch x86_64 -Os"
> I will try again without those flags and report back.
Ok. Results of a quick test... unsetting those CFLAGS and CXXFLAGS did
the trick. Of course, then configure got hung up on readline
(history), so I had to configure it without-readline. Now it is
make-ing.
>> I have no clue about MacOSX, though. On Linux, it would be
>> a 32bit/64bit mixture...
>> Markus
>>> Undefined symbols:
>>> "_pj_get_def", referenced from:
>>> _main in ccjErGbn.o
>>> ld: symbol(s) not found
>>> collect2: ld returned 1 exit status
>>> configure: failed program was:
>>> #line 7056 "configure"
>>> #include "confdefs.h"
>>> /* Override any gcc2 internal prototype to avoid an error. */
>>> /* We use char because int might match the return type of a gcc2
>>> builtin and then its argument prototype would still apply. */
>>> char pj_get_def();
>>> int main() {
>>> pj_get_def()
>>> ; return 0; }
Puneet Kishor http://www.punkish.org
Carbon Model http://carbonmodel.org
Charter Member, Open Source Geospatial Foundation http://www.osgeo.org
Science Commons Fellow, http://sciencecommons.org/about/whoweare/kishor
Nelson Institute, UW-Madison http://www.nelson.wisc.edu
Assertions are politics; backing up assertions with evidence is science
Sent from Madison, WI, United States
