[GRASS-user] problems with compile i.landsat.acca add-onn
Markus Neteler
neteler at osgeo.org
Fri Sep 4 18:34:11 EDT 2009
On Fri, Sep 4, 2009 at 2:14 PM, Saami Riet<cosmicmichi at gmx.de> wrote:
> Thank you Markus
> again...the problem with compile the add-onn under Ubuntu is not fixed,
> changed the path in the file Platform.make:
> 67 GRASS_HOME = /usr/lib/grass64/
> 68 RUN_GISBASE = /usr/lib/grass64/
> used again the command:
> sudo make MODULE_TOPDIR=/usr/lib/grass64
> and got the following messages:
> /usr/lib/grass64/include/Make/Module.make:15: Warnung: Alte Befehle für das
> Ziel »/usr/lib/grass64/« werden ignoriert
> gcc -I/usr/lib/grass64/ /dist.i486-pc-linux-gnu/include -Wall -g -O
> -DPACKAGE=\""grassmods"\" -I/usr/lib/grass64/
> /dist.i486-pc-linux-gnu/include ...
As you can see you have an illegal white space there:
gcc -I/usr/lib/grass64/ /dist.i486-pc-linux-gnu/include ...
should be
gcc -I/usr/lib/grass64/dist.i486-pc-linux-gnu/include
etc.
Please carefully check Platform.make for this (I suggest to remove the
trailing / from the
entries.
cheers
Markus
