[GRASS-user] Multiple attribute tables in winGRASS 6.4
    Sharon M
    morrisxs09 at gmail.com
    Mon Sep  7 02:33:43 EDT 2009
Hello Colin
I've downloaded and installed winGRASS r38959.
I used db.connect to define ODBC connection
Used db.login to define user
Ran db.tables -p
- this generates error with pop-up window appearing: odbc.exe has
encountered a problem and needs to close
Regards,
Sharon
On Sun, Sep 6, 2009 at 6:41 AM, Colin Nielsen<colin.nielsen at gmail.com> wrote:
> I've just uploaded a new version (r38959) with ODBC support enabled.
> Please test it out and let us know if it is working properly. I hope
> this solves your issue Sharon. (Please remember that it can take up to
> 24 hours before the new updates make it to all the web mirrors).
> -Colin
> On Fri, Sep 4, 2009 at 2:54 AM, Sharon M<morrisxs09 at gmail.com> wrote:
>> Hi,
>> I'm hoping the general GRASS mailing list community can help me.
>> I'm using winGRASS 6.4 (r38875) on windows XP and using DBF files
>> (oracle and ODBC is not currently supported in winGRASS).
>> I'm able to connect an additional attribute table containing
>> alternative names to a vector map. The cat columns in layer 1 and
>> layer 2 are the same (numbers 1-25). e.g.
>>> v.db.connect map=locn layer=2 key=cat table=locn_tbl2
>> If I bring up the attribute window manager, I can see the new table is
>> in layer 2.
>>> v.info    reports that there are 2 db links.
>>> v.info -c map=locn layer=2   reports list of columns in layer 2
>> However, commands such as v.label, d.vect.thematic, d.vect, v.extract,
>> etc are unable to access layer 2. Also, if using the windows which
>> pop-up (instead of the command line) for any of these commands, you
>> cannot change the layer option from "1" to "2" (or any other layer
>> value).
>> example output...
>>> v.label labels=alt_nme map=locn col=othnme layer=2
>> gives error...  "Sorry, <col=> is ambiguous"
>> Does anyone have any ideas as to whether multiple layers works in winGRASS?
>> Thanks in advance,
>> Sharon
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
