[GRASS-user] Multiple attribute tables in winGRASS 6.4
Sharon M
morrisxs09 at gmail.com
Mon Sep 7 03:33:27 EDT 2009
Hello Hamish (and grass users),
Ahh yes, apologies for my silly operator error. OK changed col to column.
> v.label labels=alt_nme map=locn column=othnme layer=2
returns message "Labeled 0 lines"
I still have the issue that commands such as v.label, d.vect.thematic,
d.vect, v.extract, etc are unable to access layer=2 even though v.info
reports that there are 2 attribute tables for the vector map.
If using the windows which pop-up for e.g. v.label (instead of the
command line) for any of these commands, you cannot change the layer
option from "1" to "2" (or any other layer value).
So the question still is - is it possible in winGRASS using DBF files
to run a command (e.g. v.label) to access any layer other than
layer=1?
Sharon
On Sun, Sep 6, 2009 at 1:01 PM, Hamish<hamish_b at yahoo.com> wrote:
> Sharon wrote:
>> > v.label labels=alt_nme map=locn col=othnme layer=2
>> gives error... "Sorry, <col=> is ambiguous"
> col= could be column= or color=. You need to add more letters
> there.
> Hamish
