[GRASS-user] problem importing .adf format with r.in.gdal
Tim Holland timothyholland at gmail.com
Mon Sep 7 06:38:42 EDT 2009
Hello all,
I am having some trouble importing Arc/Info Grid files into GRASS using
r.in.gdal.  I am on GRASS 6.4 on MacOS 10.5.
The data I am trying to use is estimates of global carbon density, which is
found here.
http://cdiac.ornl.gov/ftp/global_carbon/datasets.zip
The data exists at three spatial resolutions: 1km x 1km; 5minute x 5minute;
and 10minute x 10minute.  I want to import and use the highest (1km x 1km)
resolution.  The (odd?) thing is, I have successfully imported the 5minute x
5minute data, but I cannot get the 1km x 1km.
I have used r.in.gdal
>r.in.gdal input=/Users/usr/datasets/c_5m/hdr.adf output=IPCC_Carbon_5min
--o -o
It imports successfully, and
>r.univar IPCC_Carbon_5min
returns
total null and non-null cells: 500000
total null cells: 326493
Of the non-null cells:
n: 173507
minimum: 0
maximum: 372.142
range: 372.142
mean: 20.5885
mean of absolute values: 20.5885
standard deviation: 41.6786
variance: 1737.1
variation coefficient: 202.437 %
sum: 3572242.931286566
But when I try exactly the same code with the higher resolution version,
>r.in.gdal input=/Users/usr/datasets/c_1km/hdr.adf output=IPCC_Carbon_1km
--o -o
I get
WARNING: G_set_window(): Illegal latitude for North
and it will not import.
I tried using gdal_translate because that fixed a problem I had before with
'illegal latitude for north'
>gdal_translate -of GTiff -a_ullr 180W 90N 180E 90S
src_dataset=/Users/timholland/c_1km/hdr.adf dst_dataset=IPCC_Carbon_1km
But I get the message
ERROR 4: `src_dataset=/Users/timholland/c_1km/hdr.adf' does not exist in the
file system,
and is not recognised as a supported dataset name.
Also, everything I have tried with the hdr.adf file in the directory (as
shown in the above), I have also tried with the w100100.adf file, with the
same results (the 5minute resolution file works, the 1km resolution one does
not).
Thanks very much for any help.
Best,
Tim
View this message in context: http://n2.nabble.com/problem-importing-adf-format-with-r-in-gdal-tp3596544p3596544.html
Sent from the Grass - Users mailing list archive at Nabble.com.
