[GRASS-user] Re: Lidar Data automatic processing help
stephen sefick
ssefick at gmail.com
Wed Sep 9 16:21:19 EDT 2009
#!/bin/sh
FILES=$(ls /Volumes/biggun/XYZ_DATA_TILES | grep dsm)
for k in $FILES ; do
g.region vect=$k
v.surf.idw input=$k output=dem$k npoints=12 layer=0 column="Point height"
done
will this do what I want?
On Wed, Sep 9, 2009 at 11:51 AM, stephen sefick<ssefick at gmail.com> wrote:
> This is a little script that I have written to import a bunch of tiled
> x y z data into GRASS:
> #!/bin/sh
> v.in.ascii input=$k output=$k z=3 fs=" "
> done
> This is how I was doing it before:
> #lidar processing
> v.in.ascii input=/Volumes/biggun/XYZ_DATA_TILES/dsm16.xyz
> output=points_16 fs=" " z=3
> #set region to vect
> g.region vect=points_16
> #interpolate to grid
> v.surf.idw input=points_16 at lidar output=dem16 npoints=12 layer=0
> #set color map
> r.colors map=dem16 at lidar raster=dem01 at lidar
> I would also like to to have the last three commands in the shell
> script to pipe the output from 1 to 2 to 3 to 4. I am just learning
> how to write shell scripts and don't know quite how to do this.
> thanks for all of your help,
> Stephen Sefick
> Let's not spend our time and resources thinking about things that are
> so little or so large that all they really do for us is puff us up and
> make us feel like gods. We are mammals, and have not exhausted the
> annoying little problems of being mammals.
> -K. Mullis
Stephen Sefick
-K. Mullis
