[GRASS-user] GRASS project movement
Vincent Bain
bain at toraval.fr
Fri Sep 11 07:40:55 EDT 2009
Perhaps useful to raise the particular status of db data : if you use
dbf driver, the directory will be saved, but if you have an external db
connection, beware of data loss...
Le vendredi 11 septembre 2009 à 12:42 +0200, Markus Neteler a écrit :
> On Fri, Sep 11, 2009 at 9:11 AM, christian Brandt
> <chrisbrandt74 at hotmail.com> wrote:
> > Dear list,
> > I have a question in terms of GRASS project movement. I would like to
> > archive GRASS projects so that I can still use it but hence it does not take
> > needed space.
> > So if I package the complete GRASS GIS data directory does it also take the
> > total information including projection, coordinate system... or do I have to
> > start with a new project? (I did not use GRASS for a long time, so...)
> You may want to package per location. Locations are independent from
> each other (so just put each location directory in a different package).
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
