[GRASS-user] Very high resolution topographic map of Europe: need help and advices: UPDATE
Felix Schalck felix.schalck at gmail.com
Mon Sep 14 11:56:46 EDT 2009
Thanks you vezry much for your link, Benjamin. The data seems very
promising ... if only I could read it properly !
How do you import  ArcGIS Geodatabase tiles into GRASS ?
Thanks for you help and your patience,
Felix
2009/9/13 Benjamin Ducke <benjamin.ducke at oxfordarch.co.uk>:
> There is some very good hydrodata here:
> http://ccm.jrc.ec.europa.eu/php/index.php?action=view&id=24#
> Two drawbacks:
> - non-commercial use only (see license text)
> - comes as ArcGIS Geodatabase file (yuck!)
> Version 1 used to be shapefiles, maybe it's still available.
> Ben
> Felix Schalck wrote:
>> Dear All-who-may-be-intersted,
>> First, I'd like to apologize for the delay: lots of stuff prevented me
>> from working on the map. I've got some spared time now, and the map
>> isn't finished yet - so I'm back into buisiness!
>> Secondly, I'd like to thank you Markus, for the great script you sent
>> me: it worked withouth a hitch, and I have now a single big shapefile
>> to work on. And sorry for the last message: it was a misclick.
>> Then comes the map: basically, even though the last replies provided
>> my with some valuable advices, I'm still stuck with bathymetry -
>> rivers and coastlines.
>> 1. For the bathymetry, I finally took ETOPO1 data, which gives me
>> another nice raster, although of much lower resolution (1' compared to
>> the 3" topographic raster from SRTM DEM). So the plan is to cut off
>> all the land data from the ETOPO1 raster along the coastlines, to keep
>> only the sea aeras and than paste this reduced raster onto the main
>> SRTM topographic raster of greater resolution. Can this step be
>> automated ? (eg: is there a tool to do the job ?) Of course, should
>> raster-merge be to complicated, there is always the other option,
>> which is to export pngs first, and paste the pngs together; but in
>> both cases, the bathymetric raster has to be cut.
>> 2. Rivers and coastlines are a real pain.
>> a. I could import a big pasted SWBD shapefile thanks to Markus script,
>> but the cleaning process of the import command takes days, and  gets
>> somehow stuck within the brigdge removing phase. Result is an
>> uncomplete vector map, lacking centroids, which can't be further
>> processed by v.generalize for smoothing (the command dies saying there
>> is an error in input data), but can be displayed with v.display.
>> Another problem are all the square borders left around former SWBD
>> tiles in water aeras; can they be removed ? Or do I have to manually
>> edit the (huge) vector map ?
>> b. Then come the rivers: the (somehow corrupted) SWBD vector map shows
>> only coastlines, smaller closed waterbodies and - although only
>> partially - larger rivers. I somehow have to complete the river data,
>> and try following methods:
>> -r.watershed command in grass, to compute the rivers from DEM data.
>> This command just dies during the memory allocation process (KILL
>> signal) because the map is too huge for my system. I tried with
>> differend -m parameters, but the command always askes for up to 10gb
>> virtual memory the kernel won't be able to provide. I guess I would
>> have to work on smaller pieces of the map, set with g.region, and
>> paste the results together, but this is another time consuming option.
>> -VMAP0 data import works, but the result is quite disappointing. The
>> secondary rivers network seems quite good, but this datased is unable
>> to fix the uncomplete major rivers from the SWBD dataset. For an
>> instance, by showing both layers (SWBD + VMAP0) on the monitor, I get
>> all smaller rivers flowing into the rhine, while the rhine itself
>> remains divided into several un-joined segments.
>> -OSM(openstreetmap) data is a bit confusing. First it is divided along
>> countries, so you have to dowload and paste lots of different files.
>> Than the" Waterway" shapefile is quite poor. And finally the "natural"
>> shapefile comes with nice river data, but also a lot of confusing
>> data, like forest aeras. This need some sort of filtering, but I don't
>> know at all how to do this.
>> c. Of course, if someone knows better river datasets (scale approching
>> 3", complete, easy to use), I would be happy to try them.
>> Voila. Even though a lot more problems arise during each step
>> (resolution has become another one, for an instance), I hope this
>> project will see an end soon.
>> Thanks for your help and your patience,
>> Felix
>> 2009/8/17 Markus Neteler <neteler at osgeo.org>:
>>> Hi Felix,
>>> On Sun, Aug 16, 2009 at 7:37 PM, Felix Schalck<felix.schalck at gmail.com> wrote:
>>>> a - Importing the vectors from SWBD is no problem, tough It would be
>>>> nice to have the 200+ NASA shapefiles merged BEFORE importing a new
>>>> layer in GRASS. Is this possible with ogr2ogr ?
>>> Merge of two SHAPE files 'file1.shp' and 'file2.shp' into a new file
>>> 'file_merged.shp' is performed like this:
>>> # note order "out", then "in":
>>> ogr2ogr file_merged.shp file1.shp
>>> ogr2ogr -update -append file_merged.shp file2.shp -nln file_merged file2
>>> The second command is opening file_merged.shp in update mode, and
>>> trying to find existing layers and append the features being copied.
>>> The -nln option sets the name of the layer to be copied to.
>>> Attached a script to do as many as you want.
>>>> b - The big problem are coastlines and waterbodies (+main rivers):
>>>> somehow I have to show them on the topographic map, which gdalwarp has
>>>> filled out with -32768 values in nodata-waterzones. So either I cut
>>>> waterbodies out of the topographic raster along the vectors, or I
>>>> somehow have GRASS compute me all waterbodies from the vector layer,
>>>> fill them with a nice blue and create a raster which can be pasted
>>>> over the topographic raster to get the final map.  It seems doable
>>>> with mapcalc, but frankly, I do not know at all how to proceed. Any
>>>> help here would be greatly appreciated.
>>> Not sure, but set -32768 to NULL (no data) with r.null?
>>> Then use r.colors (nv to set color for NULL):
>>> http://grass.osgeo.org/grass64/manuals/html64_user/r.colors.html
>>> cheers
>>> Markus
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Benjamin Ducke
> Senior Applications Support and Development Officer
> Oxford Archaeological Unit Limited
> Janus House
> Osney Mead
> OX2 0ES
> Oxford, U.K.
> Tel: +44 (0)1865 263 800 (switchboard)
> Tel: +44 (0)1865 980 758 (direct)
> Fax :+44 (0)1865 793 496
> Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
