[GRASS-user] Orthophotos in .sid - removing black border
stephen sefick ssefick at gmail.com
Wed Sep 16 12:54:43 EDT 2009
So, I found the odd crs that the orthophotos were in used gdalwarp to
reproject the tiffs then wrote a script to bring all of the
orthophotos in and reclassed 0 as NULL, and poof the black border
disappeared.  Now I need to combine the red, blue, and green images
into one single orthophoto for display.  What would you use the three
color bands for anyway?  Thank you all for your help.
regards,
Stephen Sefick
On Wed, Sep 16, 2009 at 2:40 AM, Hamish <hamish_b at yahoo.com> wrote:
> Hamish wrote:
>> I may be dreaming, but I seem to remember writing a script to do that
>> some time ago (maybe March?) to crop the blank edges off the NOAA BSB
>> format nautical charts. try searching the archives and wiki.
>> see also the image classification modules, r.mask, and "g.region zoom=".
> nope, not dreaming. see attached.
> you'll have to adjust it to suit your needs, but the method works,
> especially if the collars are square to the image bounds.
> otherwise open the image in GIMP or whatever, use the magic wand select
> on the border, set it to 0:0:0 or 255:255:255, reapply georef with
> gdal_translate, reimport with r.in.gdal, use r.null to remove 0:0:0 or
> 255:255:255.
> Hamish
Stephen Sefick
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods.  We are mammals, and have not exhausted the
annoying little problems of being mammals.
								-K. Mullis
