[GRASS-user] QGIS: Segmentation fault
Bödőcs András bodocs at ludens.elte.hu
Mon Sep 21 08:08:04 EDT 2009
Dear Hamish and Benedikt
I appologize to join to this discuss, but I have the same problem as
Benedikt.
Since I have been changed to linux mint(ubuntu 9.04) from SUSE 11.1 I can
not start qgis. (either 1.2 nor 1.3)
the Qgis is stopping with the same segmentation error immediatelly after
the Python modules are loading into
the dpkg list which you have asking for in my system is the following:
(nincs leírás)= no description
best regards
András
Desired=Unknown/Install/Remove/Purge/Hold
Status=Not/Inst/Cfg-files/Unpacked/Failed-cfg/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Hold/Reinst-required/X=both-problems (Status,Err:
uppercase=bad)
||/ Név           Verzió        Leírás
ii  grass          6.4.0~rc5-3~ja Geographic Resources Analysis Support
System
un  libgdal-dev    <nincs>        (nincs leírás)
un  libgdal-doc    <nincs>        (nincs leírás)
un  libgdal1       <nincs>        (nincs leírás)
un  libgdal1-1.3.1 <nincs>        (nincs leírás)
un  libgdal1-1.3.2 <nincs>        (nincs leírás)
un  libgdal1-1.4.0 <nincs>        (nincs leírás)
ii  libgdal1-1.5.0 1.5.4-4        Geospatial Data Abstraction Library
pn  libgdal1-1.5.0 <nincs>        (nincs leírás)
ii  libgdal1-1.6.0 1.6.2-3~jaunty Geospatial Data Abstraction Library
ii  libgdal1-1.6.0 1.6.2-3~jaunty GRASS extension for the GDAL library
ii  libgdal1-dev   1.6.2-3~jaunty Geospatial Data Abstraction Library -
Develo
un  libgdal1c2     <nincs>        (nincs leírás)
un  libgdal1c2a    <nincs>        (nincs leírás)
ii  qgis           1.3.0-1~jaunty Geographic Information System (GIS)
2009.09.21. 13:53:06 dátumon Hamish <hamish_b at yahoo.com> írta:
> Benedikt Ziegler wrote:
>> a few days ago, I wrote a message to the german GRASS List.
>> I have trouble by startung QGIS using Linux 9.04. I've
>> installed QGIS first some month ago, and the programm worked
>> without any problems. But now, when I start there is the
>> Startup Windows but then it shut down. The Terminal gives
>> the error message: Segemtation fault.
>> Because of this error I updated the former Version 1.0.xx
>> to the unstable 1.3.0 from this Launchpad sources:
>> deb http://ppa.launchpad.net/qgis/unstable/ubuntu jaunty
>> main deb-src http://ppa.launchpad.net/qgis/unstable/ubuntu jaunty
>> main
>> But the error message is still the same as before. So I
>> think it's not really a problem of the installed version. Do
>> somebody know this and can give some advice to solve it?
> if you update from the UbuntuGIS repository make sure you update GDAL
> and GRASS from there as well.
> what does this say:
> $ dpkg -l grass qgis 'libgdal*'
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Bödőcs András, PhD
ELTE Régészettudományi Intézet
Térinformatika Labor
Budapest, H-1088
Múzeum krt. 4/b.
T: +36-1-4116554, +36-1-4855200/2910
F: +36-1-4116553
E-mail: bodocs at ludens.elte.hu
www: http://www.regeszettudomany.hu
