[GRASS-user] QGIS: Segmentation fault
Benedikt Ziegler
benesmail at web.de
Mon Sep 21 13:50:35 EDT 2009
Hello András,
it's no reason for apologize. Yes, that's exactly the same. Unfortunately I have no idea how to solve or what's the reason for it. So let's hope someone can help us. ;) I can install QGIS for Windows but I won't if I can avoid it.
Some greetings
Benedikt
> -----Ursprüngliche Nachricht-----
> Von: "BödÅ‘cs András" <bodocs at ludens.elte.hu>
> Gesendet: 21.09.09 14:09:11
> An: "Benedikt Ziegler" <benesmail at web.de>
> CC: grass-user at lists.osgeo.org
> Betreff: Re: [GRASS-user] QGIS: Segmentation fault
> Dear Hamish and Benedikt
> I appologize to join to this discuss, but I have the same problem as
> Benedikt.
> Since I have been changed to linux mint(ubuntu 9.04) from SUSE 11.1 I can
> not start qgis. (either 1.2 nor 1.3)
> the Qgis is stopping with the same segmentation error immediatelly after
> the Python modules are loading into
> the dpkg list which you have asking for in my system is the following:
> (nincs leírás)= no description
> best regards
> András
> Desired=Unknown/Install/Remove/Purge/Hold
> Status=Not/Inst/Cfg-files/Unpacked/Failed-cfg/Half-inst/trig-aWait/Trig-pend
> |/ Err?=(none)/Hold/Reinst-required/X=both-problems (Status,Err:
> uppercase=bad)
> ||/ Név Verzió Leírás
> ii grass 6.4.0~rc5-3~ja Geographic Resources Analysis Support
> System
> un libgdal-dev <nincs> (nincs leírás)
> un libgdal-doc <nincs> (nincs leírás)
> un libgdal1 <nincs> (nincs leírás)
> un libgdal1-1.3.1 <nincs> (nincs leírás)
> un libgdal1-1.3.2 <nincs> (nincs leírás)
> un libgdal1-1.4.0 <nincs> (nincs leírás)
> ii libgdal1-1.5.0 1.5.4-4 Geospatial Data Abstraction Library
> pn libgdal1-1.5.0 <nincs> (nincs leírás)
> ii libgdal1-1.6.0 1.6.2-3~jaunty Geospatial Data Abstraction Library
> ii libgdal1-1.6.0 1.6.2-3~jaunty GRASS extension for the GDAL library
> ii libgdal1-dev 1.6.2-3~jaunty Geospatial Data Abstraction Library -
> Develo
> un libgdal1c2 <nincs> (nincs leírás)
> un libgdal1c2a <nincs> (nincs leírás)
> ii qgis 1.3.0-1~jaunty Geographic Information System (GIS)
> 2009.09.21. 13:53:06 dátumon Hamish <hamish_b at yahoo.com> írta:
> > Benedikt Ziegler wrote:
> >> a few days ago, I wrote a message to the german GRASS List.
> >> I have trouble by startung QGIS using Linux 9.04. I've
> >> installed QGIS first some month ago, and the programm worked
> >> without any problems. But now, when I start there is the
> >> Startup Windows but then it shut down. The Terminal gives
> >> the error message: Segemtation fault.
> >> Because of this error I updated the former Version 1.0.xx
> >> to the unstable 1.3.0 from this Launchpad sources:
> >> deb http://ppa.launchpad.net/qgis/unstable/ubuntu jaunty
> >> main deb-src http://ppa.launchpad.net/qgis/unstable/ubuntu jaunty
> >> main
> >> But the error message is still the same as before. So I
> >> think it's not really a problem of the installed version. Do
> >> somebody know this and can give some advice to solve it?
> > if you update from the UbuntuGIS repository make sure you update GDAL
> > and GRASS from there as well.
> > what does this say:
> > $ dpkg -l grass qgis 'libgdal*'
> > Hamish
> > grass-user mailing list
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> BödÅ‘cs András, PhD
> ELTE Régészettudományi Intézet
> Térinformatika Labor
> Budapest, H-1088
> Múzeum krt. 4/b.
> T: +36-1-4116554, +36-1-4855200/2910
> F: +36-1-4116553
> E-mail: bodocs at ludens.elte.hu
> www: http://www.regeszettudomany.hu
______________________________________________________
GRATIS für alle WEB.DE-Nutzer: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://movieflat.web.de
