[GRASS-user] Re: Strange r.mapcalc results
Hermann Peifer peifer at gmx.eu
Thu Sep 24 02:35:12 EDT 2009
 > r.univar based comparison:
What if there was a small geometric shift between the 2 maps. Would I
notice if both maps have enough NULLs around the edges?
 > r.mapcalc "diffmap = map1 - map2"
How would I separate NULL,NULL cases from cases where one map has a
value, but the other has NULL?
And after thinking twice about my earlier posted test results, I still
do not understand the logic of the isnull() results:
isnull(mapA) && isnull(mapT) gives NULL (Test1)
isnull(mapA) && isnull(mapT) gives 1    (Test3)
This doesn't make sense to me, which might be my fault, though.
Test1
$ r.mapcalc 'result = isnull(mapA) && isnull(mapT) || mapA == mapT ? 1 : 2'
$ r.stats -c result
1 799796
* 3200204
Test3
$ r.mapcalc 'result = isnull(mapA) && isnull(mapT) ? 1 : mapA == mapT ?
2 : 3'
$ r.stats -c result
1 3200204
2 799796
Hermann
Hamish wrote:
> Hermann wrote:
>> I am trying to find out if 2 raster layers are exactly
>> identical.
> I usually do
> g.region rast=map1,map2
> r.univar map1
> r.univar map2
> and make sure the output is the same.
> another way is
> r.univar diffmap
> see also wish #618
>  https://trac.osgeo.org/grass/ticket/618
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
