[GRASS-user] strange behavior of i.cluster with sample=1,1
Sylvain Maillard
sylvain.maillard at gmail.com
Thu Sep 24 10:40:18 EDT 2009
dear grass users,
i'm working on landsat imagery and i need to do some automatic
classification so i'm doing several tests with i.cluster (first, after that
i will also try i.cass or i.gensigset). As I wanted to see the impact of the
"sample" parameter, i launch a script with several variations and i noticed
this result: when the sample parameter is becoming smaller, i.cluster tend
to converge to only 1 class ...
I was thinking that with more samples the result will be more accurate but
it seems to be the oposit ... with the default value for sample, the result
is always correct ...
Is there something wrong with the fact to use sample=1,1 (or sample=10,10)
instead of the default value sample=56,71 ?
for the moment i'm working with landsat 5 or 7 imagery, so in the case of
land use with a very reduce location (ex: "small" rivers), having samples
only each 56x15m=840m can occult some land use category ...
I have the same error on gras 6.3 or 6.4, grass did'nt notice any error,
and I have enought of ram (only 65% used) ... do you have an idea of what is
going wrong and what can i try to solve this problem?
I join the results of i.cluster with 20 classes and sample=1,1 parameter
set, the others have default values => it goes wrong imediately ... and with
default sample (56,71), everything works ...
Paramètres du cluster
Nombre de classes initiales: 20
Taille minimum de classe : 17
Séparation minimum entre classes: 0.000000
Pourcentage de convergence: 98.000000
Nombre maximum d'itérations: 30
Intervalle d'échantillonnage en ligne: 1
Intervalle d'échantillonnage en colonne: 1
Taille de l'échantillon : 40439680 points
Distribution des classes
1826562 24892 450783 312030 852164
1646111 2323198 2780468 3019891 3214292
3472239 3559417 3246739 2739526 2249348
2013603 1977504 1754731 1225898 1750284
######## itération 1 ###########
2 classes, 0.01% points stables
38277534 0 0 0 0
0 0 0 0 0
0 2162146 0 0 0
0 0 0 0 0
######## itération 2 ###########
1 classes, 5.35% points stables
0 0 0 0 0
0 0 0 0 0
0 40439680 0 0 0
0 0 0 0 0
######## itération 3 ###########
1 classes, 100.00% points stables
0 0 0 0 0
0 0 0 0 0
0 40439680 0 0 0
0 0 0 0 0
Sylvain Maillard
Doctorant en Sciences de l'Environnement
Laboratoire Chimie Provence - UMR 6264 / Université de Provence
la Tour du Valat - Centre de recherche pour la conservation des zones
humides méditerranéennes
Le Sambuc
13200 Arles
France
mail: maillard at tourduvalat.org
tél:04.90.97.29.79
fax:04.90.97.20.19
www.tourduvalat.org
-------------- section suivante --------------
Une pi?ce jointe HTML a ?t? enlev?e...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090924/5c5b2c0f/attachment.html
