[GRASS-user] stream network extraction
annagrass6
annagrass6 at gmail.com
Thu Sep 24 11:33:21 EDT 2009
Hi Markus, hi all,
I'm trying to compilate the code of r.stream.extract (from addOns) but when
I run "make" command it gives me this error:
annalisa at annalisa-laptop:~/grass_dev64/raster/r.stream.extract$ sudo make
test -d OBJ.i686-pc-linux-gnu || mkdir -p OBJ.i686-pc-linux-gnu
gcc -I/home/annalisa/grass_dev64/dist.i686-pc-linux-gnu/include -g -Wall
-I/usr/local/include -DPACKAGE=\""grassmods"\"
-I/home/annalisa/grass_dev64/dist.i686-pc-linux-gnu/include -o
OBJ.i686-pc-linux-gnu/close.o -c close.c
close.c: In function ‘close_streamvect’:
close.c:33: warning: format not a string literal and no format arguments
close.c:152: warning: format not a string literal and no format arguments
close.c:184: warning: format not a string literal and no format arguments
close.c:210: warning: format not a string literal and no format arguments
close.c:218: warning: format not a string literal and no format arguments
close.c:221: error: too few arguments to function ‘Vect_build’
close.c: In function ‘close_maps’:
close.c:242: warning: format not a string literal and no format arguments
make: *** [OBJ.i686-pc-linux-gnu/close.o] Error 1
"close.c:221: error: too few arguments to function ‘Vect_build’"
Where am I going wrong?
thanks
Anna
2009/9/23 Jarosław Jasiewicz <jarekj at amu.edu.pl>
> Markus Metz pisze:
>> Jarosław Jasiewicz wrote:
>>> rest of r.stream* modules including new r.stream.stats for Hortonian
>>> statistics are now available by grass addons page and by grass add-ons svn
>>> repository. I actually move tutorial on r.stream* to grass wiki page.
>> Great, IMHO the tutorials on your website are very helpful and show nicely
>> all the various results the new r.stream.* modules can produce. Maybe a link
>> to the wiki page can be added to the manuals?
>> Markus M
> Will be,
> Jarek
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090924/fc268f50/attachment-0001.html
