[GRASS-user] Re: r.stream.order problem making on mac os x
stephen sefick ssefick at gmail.com
Sun Sep 27 18:53:28 EDT 2009
I found this:
Process:         r.stream.order [74338]
Path:            /Applications/GRASS-6.4.app/Contents/MacOS/bin/r.stream.order
Identifier:      r.stream.order
Version:         ??? (???)
Code Type:       X86 (Native)
Parent Process:  bash [74313]
Date/Time:       2009-09-27 17:25:16.172 -0500
OS Version:      Mac OS X 10.5.8 (9L31a)
Report Version:  6
Anonymous UUID:  AA611A0B-FCCB-4FAB-8FCC-6E661CB57A3F
Exception Type:  EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000001
Crashed Thread:  0
Thread 0 Crashed:
0   libgrass_gis.dylib            	0x00080877
G__name_is_fully_qualified + 23 (nme_in_mps.c:66)
1   libgrass_gis.dylib            	0x000822bc G__open_raster_new + 60
(opencell.c:640)
2   r.stream.order                	0x0000213e write_maps + 46
3   r.stream.order                	0x00002b71 main + 897
4   r.stream.order                	0x00001a56 start + 54
Thread 0 crashed with X86 Thread State (32-bit):
  eax: 0xbfffc100  ebx: 0x0008228d  ecx: 0x00082b55  edx: 0xbfffc200
  edi: 0x00000001  esi: 0xbfffc100  ebp: 0xbfffc0c8  esp: 0xbfffc0bc
   ss: 0x0000001f  efl: 0x00010292  eip: 0x00080877   cs: 0x00000017
   ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
  cr2: 0x00000001
Binary Images:
    0x1000 -     0x3fff +r.stream.order ??? (???)
<7ba7322bd390054caeff9595a09fd4d0>
    0xb000 -     0xffff +libgrass_datetime.dylib ??? (???)
<5db41a672f765dfa7bcb6b3069beba0a>
/Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_datetime.dylib
   0x64000 -    0xa0fe7 +libgrass_gis.dylib ??? (???)
<bf887db89bcb7094a6af0e2b0d157a0b>
/Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_gis.dylib
0x8fe00000 - 0x8fe2db43  dyld 97.1 (???)
<458eed38a009e5658a79579e7bc26603> /usr/lib/dyld
0x9053a000 - 0x90548ffd  libz.1.dylib ??? (???)
<5ddd8539ae2ebfd8e7cc1c57525385c7> /usr/lib/libz.1.dylib
0x9137c000 - 0x914e3ff3  libSystem.B.dylib ??? (???)
<ae47ca9b1686b065f8ac4d2de09cc432> /usr/lib/libSystem.B.dylib
0x96b0b000 - 0x96b12fe9  libgcc_s.1.dylib ??? (???)
<f53c808e87d1184c0f9df63aef53ce0b> /usr/lib/libgcc_s.1.dylib
0x97361000 - 0x97365fff  libmathCommon.A.dylib ??? (???)
/usr/lib/system/libmathCommon.A.dylib
0xffff0000 - 0xffff1780  libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
On Sun, Sep 27, 2009 at 5:43 PM, William Kyngesburye
<woklist at kyngchaos.com> wrote:
> Is that all the binary images lines?  If so, then somehow compilation didn't
> link the GRASS libraries.
> There are no changes listed in grass-addons SVN after it was added, so I
> can't tell if something changed in the Makefile since it last worked for
> you.
> On Sep 27, 2009, at 5:23 PM, stephen sefick wrote:
>> Is this what you were talking about?  If it is not I can find it if
>> you tell me what I am looking for.
>> Process:         r.stream.order [73041]
>> Path:
>> On Sun, Sep 27, 2009 at 4:37 PM, William Kyngesburye
>>> There should be a crash log for r.stream.order, which you can find in
>>> your
>>> home logs with Console.app.  The trace is especialy useful, though the
>>> binary images info can be helpful.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
Stephen Sefick
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods.  We are mammals, and have not exhausted the
annoying little problems of being mammals.
								-K. Mullis
