[GRASS-user] Database driver problem
grassyjohn jf_walsh at hotmail.com
Mon Sep 28 07:02:09 EDT 2009
Thanks for the tip but I've no idea of how to "re-compile" .  Can this be
done from within the software or do I need to use something like Dev C++?
I have a box running on Vector Linux so I may just install on there instead.
Maris Nartiss wrote:
> Unfortunatly GRASS has no Windows developers. Developers use Linux or
> Mac and not windows and thus fixing Windows specific bugs is hard.
> I have attached patch to ticket where such problem is described.
> http://trac.osgeo.org/grass/ticket/629
> Please, apply patch to GRASS 6.4/5, recompile and run with DEBUG=1.
> Post Your results to ticket.
> Thanks,
> Maris.
> 2009/9/27, grassyjohn <jf_walsh at hotmail.com>:
>> I've tried importing the spearfish_contours files via File-->Import
>> Vector
>> Map-->Multiple Formats Using OGR and get this message
>> Invalid argument: can't _spawnl
>> Unable to start driver <sqlite>
>> Unable open database
>> <D:/GIS_DataBase/Spearfish60/user1/dbf/spearfish_contours.db> by driver
>> <sqlite>
>> I've tried using dbf and ogr database drivers but the result is the same.
>> I'm using GRASS 6.4 on Windows XP.  Has anyone come across the problem?
>> View this message in context:
>> http://n2.nabble.com/Database-driver-problem-tp3720138p3720138.html
>> Sent from the Grass - Users mailing list archive at Nabble.com.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://n2.nabble.com/Database-driver-problem-tp3720138p3728795.html
